You should be over 10 psi with the 3 inch exhaust and no cats, and if your not, you have a boost leak somewhere. You shouldnt even need a boost controller with that stuff. And your probably pushing your stock injectors at about 12-14 psi. The stocks will run to fuel cut fine, So your limiting factor is going to be fuel cut off untill you get the lex afm/550s in and you probably still wont need a boost controller then. lol.
