Thread: Tune Up
Old 01-19-2007, 03:58 PM   #2
scruffboy
scruffboy's Avatar
Default Thanks
I'm always fiddlin around with the car and have a lot of the stuff on your list checked off already. Got the O2 Sensor, Thermostat, air-filter, had to replace a broken coolant temp. sensor, then found a leak after the AFM and fixed that. Adjusted TPS and other minor things. Can you answer a question for me? What's the difference between the AFM (Air Flow Meter I assume?) and the MFA (or is it MAF)?
Thanks,
Scruffboy
P.S. The stupidest question is the one not asked.
