Thread: Heat??
Old 01-23-2007, 12:13 AM   #1
burton51m
burton51m's Avatar
Default Heat??
my heat is being a **** again and i dont know why. my car used to heat right away with in 10-15 min, now it takes forever like 10 minutes later than it should. and the heat is not constant or hot at all.(barely any heat now)
also when i step on the gas you can feel the air warm up coming from the vents.
i alread did the VSV vacuum hose trick earlier in the year and it worked for about 2 months. could my heat be going?
1 more thing, i was messin with my aftermarket alarm down by the fuse and kickpannel...is there a wire or fuse that i could have bumped that made the heat go out on me?
thanks
