I'm not sure, and infact it's probably not the case...but I had the same problem for a month and today it got worse. I started my car and the idle dropped severely and felt like the car was going to stall ( and I have an automatic ). Well later on tonight I had steam pouring from my hood...sure enough blown head gasket. i could literally see the anti freeze pouring from the block turning into steam as it hit the hot engine parts below. So you may check for BHG? I would check the air filter to be safe, check your fuel lines...fuel filter...shoot buddy there's a few things to check out anyways.
