Old 05-22-2005, 03:40 AM   #15
monkihead
SP58GT
monkihead's Avatar
Originally posted by hangsupra@May 17 2005, 03:23 PM
you only find air leak if the air sucking in only... if the air is leak n blow it out... the carbu. spray wouldnt help at all... it only help you when you find a leaking air that sucking in only tho.
1.the dont have a carb. 2nd if it has a vaccum leak, spraying carb cleaner or throttle plate cleaner will cause the idle to rise. doing so, lets you know if you have a leak. if you dont, nothing happens to the idle.
monique- better off dead
