rude1978: if you are lucky you might have the owners manual for your car... have a flick through it and see if the code has been written down somewhere... have a look anywhere in the car thinking if it was you where you would write it down
if no luck with owners manuals for it... try your local toyota dealer
all you should need is the serial number of the stereo and your make and model of car i believe... they should be able to just give you the pin and instructions on how to unlock it
bhf56a: i don't remember any theft deterrent on mk3's
i would actually pull the radio and i bet you'll find shoddy wiring... power wire may have just pulled apart or something
or the stereo may be fried.. pull it and check it out
Pics of my build.
Do a diagnostic first!
