Originally Posted by liona
GreetingS to all!
Need help pls with HIGH and UNSTABLE idle. Idling RPM fluctuates up and down between 1400 to 1800. I sprayed the vacuum hoses connections with carb cleaner, and don't appear to have any vacuum leaks. Timing set at 12 deg BTDC.
I did notice a crack (which I temporarily tape wrapped) near the hose clamp on the big hose/tube connecting the turbo to the air cleaner . Could this be causing the erratic idle? If not, pls advise whatelse could be causing it.
THANKS MUCH IN ADVANCE FOR YOUR HELP!
any vacuum leak can be causing erradic idle.
any cracked hose is bad news. replace it regardless
Its broke, it could be anything, and cost of repairs will greatly exceed the value of the car
