Old 01-30-2007, 02:40 AM   #1
Caliturbo88
Caliturbo88 is on a distinguished road
Default # 5 cylinder DEAD!???
Well on the 86 i got, number 5 cylinder just died off one night driving home. Its a NA motor. We had all the injectors professionaly flowed and new spark plugs and wires(its getting spark and fuel). What would cause the cylinder to loose compression? i can tell its not getting nearly enough compression on number 5 because when you crank the starter, it raises and lowers rpm as it tries to turn over. Could it possibly be something besides worn rings or not sealing valves?
Caliturbo88 is offline   Reply With Quote
