I didn't see anything about your ISC valve. If its dirty or has a bad connection there is no telling where your idle will be. If its putting your idle too high and everything else is good then your system would normally cut the fuel when it gets too high and you would get the idle cycling up and down between 1600 to 2000 or so.
