^^^^ Yes, the first step is to flush the trans. Make sure you take it to a shop that uses the machine to do it. Not just drain and fill, as that will only get 2 1/2 qts. out.
The machine method cleans insides with a mild chemical then removes all the old oil, and reloads with all new oil.
