Old 02-04-2007, 12:55 AM   #13
mrnickleye
mrnickleye's Avatar
Carb spray down the holes will work. Or brake cleaner spray is less strong, safer.
The oil down on the spark plugs/boots can cause a misfire. You need to fix the leak. Usually the V/C gaskets, #1 & #2. Not the center one. Not a difficult job at all.
