Originally Posted by Murd
You don't need a metal head gasket if you're going to be running stock boost or slightly over stock. Just make sure it's torqued to 70-80ft/lbs. If you're not getting the block lapped you're probably better off NOT getting a metal head gasket as well... Both surfaces need to be extremely smooth to use a metal one. Get a stock head gasket kit from toyota, it should have all the parts you need in it, grommets and all. I'd suggest still taking the head to a machine shop however.
what id love to do with the car is leave the turbo as it is, then slowly phase in some other parts....which i havent decided yet :-P or maybe i wont, ill just have fun with it and see how long i can keep her alive. either way, she isnt going above 300 HP unless i hit the lotto.
i just wanna fix this problem so i wont have to worry when im driving the supra...much like im worrying now haha. and if i get that stock head gasket kit from Toyota, that wont include ARP studs\bolts, correct?
whats the difference between studs and bolts, anyways?
thanks for all the info
