Old 02-07-2007, 09:18 PM   #1
Supra2NR
Supra2NR's Avatar
Omg did you jus say if you invest 20k on fwd car it will drift???
Please not this again
But I will say this, that fwd will slide
But it will never drift,unless your a drift god and can control a car's movement inch by inch perfectly
Which I believe will take years to achieve
And probly 100k+ dollars of money
Paying for crashes, tires, fuel, broken parts, tires again, modding the car
Basically its not worth-it
If you really wanna get into drifting
Try to find a car with a close 50-50 balance
This will make it easier to learn with
The mk3 is not that bad, but since its front heavy it tends to pivot in a turn and spin out
But be prepared for a high price
You will spend about 10grand on the rearend alone for your suspension setup
And then you gotta worry about getting power
I'm in the same stage as you are
And money has always stopped me
