Yes you must set BASE ignition timing after adjusting the TPS. You do know how to do that right? You don't just clip a timing light on and start moving the CPS. You must disable the electronic advance which is very easy.
If that doesn't fix your problem, the only other thing would be a vacuum leak, which are always fun to find.
