Old 02-09-2007, 01:08 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Chomper
I have a 93 supra and having problems with it. First the engine light and warning light turns on...
Use this tech article to check the code(s) that is/are triggering the engine/warning lights:
http://www.mkiv.com/techarticles/eng...bd1_codes.html
...it's as simple as jumping TE1 and E1 in the diagnostic port, turning the key on, and counting the flashes. If you post the code(s) here, we may be able to help you to resolve the condition(s) that is/are triggering the code(s).
...Drove fine for a week then starts to idle very low. Low enough to kill the engine. It also seems like the power is not there anymore. I'm wondering if its the spark plugs or the distributor...
  1. What modifications does your Supra have?
  2. When did you last change the spark plugs, and the air filter?
Life begins at 30psi.
