"If you unbolted the engine mounts and raised the engine that would be the only way.Not sure if that would give you enough clearance ,but that's about your only option to look into."
Nope totally wrong.
To remove the oil pan with the engine in place you must support the engine from above and remove the front suspension crossmember. There are 2 bolts near the rear and 4 nuts up front. You also must remove the sway bar end links. Unbolt the struts from the body. And then the obvious stuff like the exhaust front pipe and stiffener plates.
Look at the TSRM LU-5 to LU-12 if you don't believe me.
