Old 02-13-2007, 03:37 AM   #1
scruffboy
scruffboy's Avatar
Question Ignition Coil or Igniter?
Is the ignition coil and the igniter the same thing? I'm talking about an N/A. The thing that sits behind the "diagnostics" box. Also, when checking resistance with ohm-meter, should car be running, not running with key turned to "on" position or not running no key? Also while I'm here, when setting throttle position sensor with ohm-meter, car running or off? Thanks guys.
Scruffboy
