what does the knock sensor do exactly? why would it cause it to feel like its looseing power or dragging behind like im towing somthing.
also i have mixed gas for the first time
Safeway gas 92 octane 1/2 Tank of gas
chevron 92 octane w/techron 1/4 tank of gas
could this be causeing the issue
and one last possible the BOV might be leaking from the IC i can feel vacume when i put my hand on the seal.
7MGTE - 500hp  never dyno'd
fidenza cam gears
