The oil could be either engine oil coming from the rear main seal (crank seal), or the front trns seal.
You need to determine which it is. Engine oil, or gear oil.
Rear main seal is a hellofa job to do. Tranyy seal is a 'pull the trans' job. Not as difficult, but still a bunch of work.
Hopefully you'll have a friend that's removed a tranny help you the first time.
