When I got my car 4.5 yrs ago, I researched the hell outa getting more power, without doing an engine overhaul and expensive parts.
Read:
http://www.toyota-supra.info/forums/...read.php?t=957
I got a kit (adaptor plate and K&N style filter) from eBay for $25. I mounted it to the AFM, then made a box (plastic flat pieces) around the air filter so only cold, outside the hood, air goes into it.
Just putting a filter on (removing the factry airbox) will actually loose you a few hp. Hot, underhood air, is NOT what you want to suck into the engine.
You might check this out.....
Quote: You Know, March Makes A Great Ram Air Kit For Mustangs That Can Be Easily Adapted To A Mk-3. The One A Friend Of Mine And I Used WAS For A 96 Mustang.
