ive got a stage 3 xtd 6 puck, i recommend it if you drift and race alot and by alot i mean about every other day or every day because it engages so harsh. you have to bring it to about 1500 or 2000 rpms and drop it, when you let off slowly it shakes the car violently like the pressure plate isnt active all the way. but it does give some good griping
7MGTE - 500hp  never dyno'd
fidenza cam gears
