Did you replace the fuel injector insulators? Those rubber things that go inbetween the injector and cylinder head. Did you replace the o-rings? The rubber o-rings that go on the injector inside fuel rail.
What did you torque the upper intake manifold to? Did you clean all of the stuck on gasket material off of the mating surfaces?
You said you changed out your fuel injectors, what did you swap them with?
