well the only light i can think of that has a picture of a car is the tail light failure sensor thingy. turn on your lights and make shur the brake lights are working, signals and all, and then try it with the brakes applied. if its like mine your tail light bolts are tightened all the way and water is getting in there and setting off the sensor. it will turn off in a couple of days at the most.
or you might have a special edition supra that has a warning light that says your car is about to blow up
naw thats your tail lights dont worry about it.
as for the other things i have no clue.
7MGTE - 500hp
never dyno'd
fidenza cam gears
