Mine went on today, also. It is a warning light that tells you that a bulb out. My bulb was blown, because today we had a lot of rain, and my tail end was parked so that a lot of water blew into the fixture and got on the bulb.
Warning light came on while sitting at a long red light with the brake lights on, and bulb got hot, and popped a little hole in it.
The seal on the tail light lenses has been discussed several times over the past 3 years, because it is a known problem.
You can do a search and find some threads on how to fix the leaking problem.
