yo i'd make sure u get a car that you check the tags on it to make sure it has the 3.9 or the 3.7 rear end cause if ur driving many miles (highway or high speeds) everyday it will work the engine harder as well your fuel economy will go in the shitter, with gas prices today if u get one with a 4.3 rear end. i think the code for a 4.3 is a 28, but the easiest way to check is test driving and if your going 60 in top gear and turning around 2500 rpms.
