am I missing something here???? As far as I know, every car or truck that I have driven in the past 25 years, including brand new cars while I worked at car dealerships, there is not one car with manual transmission that will not grind at times when you put it into reverse. It's as common as the turn indicator on a car not turning itself off while making a lane change on the freeway. There is no solution, just accept it, put the car in any forward gear, pull the clutch out enough to move the car forward an inch then go back into reverse.
