Originally Posted by 88Tsupra
hey wha program did u use to design the bodykits and etc on the supra...buh as for the first widebody kit pix is the air duc in the back going to flow through it or is the wind going to get cought inside the duc..cuz if it gets cought wouldnt that slow ur car down...buh besides that real nice man real nice..love the color too
the program is 3d studio max by autodesk go here to get a trial, www.discreet.com
the point is that if you can affoard a wide bodykit, you can afford to do a piggy bank system or somthing, so that means no more AFM just turbo
i love that color mines silver i want to get it lowered with the JC. creations wide body kit in the rear. but i wouldnt mind having one like that designed for me it would be pretty sick
7MGTE - 500hp  never dyno'd
fidenza cam gears
