That was stupid of me. I thought it would be like hondas, by ecu. I found it and the code seems to be 21. That means its the oxygen sensor? should I just replace it? Do you know if it can cause the low idling problem, or is that something else?
thanks for your help
Originally Posted by pwpanas
No...look for the OBD diagnostic port under the dash, by the door on the driver's side. There's also another diagnostic port at the back (firewall) side of the engine bay, above the downpipe.
