Old 03-06-2007, 03:42 PM   #105
IHateHacks
IHateHacks's Avatar
"I just put a new head gasket on my supra and that wiring runs over the top and then down the drivers side of your tranny. If I remember correctly there are bolts that hold it onto the tranny."
Yes, I know it bolts to the tranny, I was asking how to DISCONNECT the connectors as they are above the transmission. And the wiring goes through the lower intake manifold, therefore preventing the head to come off the block WITH the lower intake manifold still bolted on. Or it prevents the lower intake manifold to come out of the engine bay for cleaning. Problem was solved about 2 months ago, by doing what jfunez said.
"Do you have any more pics of your engine around the starter area. I have a couple of plugs on my wiring harness and I cant find out where they go."
Yes, I have plenty of more pictures. Why don't you post pictures of the connectors that you do not know where they go and Ill tell you where they go.
"QUICK question i have oil near the fan belt i dont know whas its called buh its the metal shit that connects the motor fan to the motor..is that a BHG or just some really F'en bad oil leak and how can it be fix"
Sounds like your fan clutch fluid coupling is leaking. What ever happened to starting your own thread instead of hijacking a thread that has nothing to do with your problem? Take a picture and post it. Pictures speak louder than words. If you don't have a camera, get a job.
