Oil on top of the spark plugs has nothing to do with the electrode side (the part of the plug that is in the combustion chamber) or the head gasket.
"was it the pix were ur head gasket lookd like oil was sitting there for along time"
I have no idea what you are refering to.
"and if i just get a stock size HG will it still blow on me if its not a MHG"
It's not the gasket that fails it's the head bolts. They were undertorqued at the factory, causing them to strech. As long as you properly torque the head bolts it doesn't matter what gasket you use.
