Have you worked on a Supra before because If you know alittle about these cars you can probably try and do it your self as long as you have some standard tools and some knowlege about cars. I did my first hg on my Turbo Supra when I was 16 and that was the first time I really worked on a car and I feel that since I did it my self I feel much better knowing that it is done right.
If you take it somewhere then you will need to tell them not to torque the headbolts to 58FT LBS(That was the OEM torque which caused Supras to blow gaskets in the first place). You should get some ARP bolts and torque it down to 75FT LBS.
Also is your car overheating or do you have any codes?
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
