As far as your oil leak around the cam covers you might wanna take a look at the sticky "Got oil on top of your spark plugs?". If that does not apply to you, then you just need new cam cover seals. Not a dealer only part. You can buy them at any parts store for around $30.
As far as the water around your exhaust tip, if you still have the cat on it, thats perfectly normal. You see, a catalytic converter oxidizes, reduces and converts exhaust gases which are HC (hydrocarbons), CO (carbon monoxide) and NOx (oxide of nitrogen) into CO2 (carbon dioxide), N2 (nitrogen) and H2O which is water (duh).
Edit: oops I just saw that you posted in that thread. My advise to you is to replace all the hoses that attach to the cam covers. That would be the 2 PCV hoses (the 2" ones right in the middle of the covers) and the big hose that is to the right of the oil cap. I can guarantee you if you take that big hose off when you take the covers off, it will crack. It's a dealer only part and its $25.95.
