Gas + oil
ok so i got a gas smell to my oil, as you might remember i have got a code 52 knock sensor going on, it use to be just when i boosted a little past stock, but now its starting to come on all the time, i went and added some coolant, and while i was there i checked the oil, its 1/2 full and has a smell of gas to it, oil rings? EGR? piston rings?
for the code 52 i did check my CAT, and it was slightly melted, made a test pipe to replace it, its still going on, the gas smells fine though its not smelling rich or anything. but my main cocern are those 2 issues.
what you guys think?
7MGTE - 500hp  never dyno'd
fidenza cam gears
