ok well me and a friend did some inspecting on the car, 02sensor is fine a little dirty but not enough to mess anything up and we checked the voltmeter and it says its good. EGR filter looks good, theres a little burn mark smaller than a cigerette burn in it but looks new. we pulled off the valve covers, cams sit a little odd, the drivers side cam sits perfectly in slot where the timing gear is, but the passenger one is coming out pretty good amount is this normal? <ill post a picture showing what im talking about.) then last but not least we looked at the spark plugs, cylinders 1-5 look good and barley used cylinder 6 looks brand new why?
today we will check out the injectors and possibly change the oil filter. and if we have the time we will do a compression check.
7MGTE - 500hp  never dyno'd
fidenza cam gears
