Thread: Gas + oil
Old 03-15-2007, 08:37 PM   #10
grygst76
grygst76 is on a distinguished road
If cylinder 6 plug looks new, then that plug is either not firing, or thats where the leaky injector is, you need to check that out by pulling th e 6 plug wire off and grounding it by pointing it at the block or a piece of exposed metal off and have someone start the car and see if spark is coming from the plug, if there is then leaky injector if not bad plug wire or ciol
89 Turbo, no mods yet
5 speed mbc to 10psi
grygst76 is offline   Reply With Quote
