well i looked once again, i lied it was 5, but i thought well while im here i might as well clean up the motor, so i moved the coil pack, painted the valve covers, and some bracket thingys. we just finished putting some fresh 10W 30 oil in it and a new oil filter, but not starting it till i get some more oil cause its barley on the bottom of the dipstick.
7MGTE - 500hp  never dyno'd
fidenza cam gears
