Old 03-16-2007, 07:57 AM   #1
ARZ
ARZ is on a distinguished road
Default 13 inch Wilwood MKIII front brakes
THIS IS A BOLT ON KIT!!! All you need to complete the install is brake fluid and tools.
CLICK HERE TO SEE THE REAR BRAKE KIT
Our kit consists of:
2, 13 inch diameter x 1.38 inch thick directional curved vane Wilwood rotors
2, Rotor hats, specifically made to fit the MKIII hub (These will include all the grade 8 fasteners)
2, Wilwood 4 piston "Forged" Superlite Calipers
2, Caliper brackets and "press fit" threaded inserts installed
2, Brake lines "braided stainless steel" with all the required fasteners to install in the factory brake line retainers.
4, Brake pads, Wilwood Street Compound = low dust = excellent cold performance
And all the EXACT fasteners required to make this a bolt on kit.
If you want a sample of how fast these brakes can stop your vehicle, please contact me for a test ride, and I will promptly HANG YOU ON THE BELTS. I do not recommend doing repeated brake demos if you dont have new motor mounts...IM 100% SERIOUS!!!!
You have never felt a Supra stop like this. You wont be dissapointed in these brakes.
Heres the install thread Wilwood front brake install thread
Now for the price $1195!!! plus shipping and handling.
Please Email arizonaperformance@cox.net or call 480 861 0586
MKIV coming shortly.
89 Turbo 5 Speed hard top
1971 240 Z, 7MGTE, 5 speed, 487 RWHP @ 23 PSI, weighing 2505 lbs.
www.ArizonaPerformance.com
ARZ is offline   Reply With Quote
