Thread: 1jz in an 87?
Old 03-17-2007, 06:23 AM   #1
EJ8R
EJ8R is on a distinguished road
Default 1jz in an 87?
Now I know that there is lots of info around as to what I need for parts. Here is what I've gathered so far.
~1jz Motor mount adapter brackets (do I have to get the front cross member from an 89+ if I get these?)
~Toyota 2JZ-GTE high pressure power steering hose
~Substitute found @ partsamerica.com 44403-14020
~Toyota 2JZ-GTE power steering union bolt 90401-16014
~Toyota 2JZ-GTE throttle cable 78180-1B090
~Pressure port gasket #2 44327-26020
~Pressure port gasket #1 44327-12010
~2JZ Valve cover gaskets Int 11213-46020 Exh 11214-46010
~Toyota Supra 89+ front crossmember
~Toyota Supra89+ fluid motor mounts or custom mounts 12361-42050
Here is my question, where do you recommend buying the swap from? I looked around and most people say get a front clip but what about the 1jz swap from a site like jdm-online.com?
If I buy that kit is the tranny going to work out or should I not bother? Sorry if I sound like an uber noob but this is pretty new to me, I am a honda guy by nature, just got sick of no power lol. Anything else I'm missing? Thanks guys.
EJ8R is offline   Reply With Quote
