Remember, there are 2 VSV's on MK3 supras. One is for the EGR valve and when standing on the driver side, looking at the intake manifold, its the one on the right, you can actually see that one. That one bolts to where the upper intake manifold and lower intake manifold meet. MK3's have a two piece intake manifold, if you did know that already. The one for the FPU is the one on the left and you can not see it unless the upper intake manifold is off. It is bolted to the lower intake manifold, where the intake manifold bolts to the head. Unbolting it is one thing, trying to disconnect the connector is the hard part.
