I bought a MKIII acouple of years ago and the PS was not working even after the guy had put a new PS rack on. I brought the car home and put a new pump on it thinking that..that had to be it. No fixy. I took the lines loose and made sure the pump was pumping fluid, but I only did it for a second so I wouldn't make a big mess. Fluid seemed to run through them fine. So I took the reservior off because it was the only thing left and it was clogged completely up. Cleaned it out put it back together and it's been fine ever since. Good Luck
Mark
