I had a Cam position sensor priced out at a Toyota dealer last year and it was $500. And it is a dealer only part.
But you can run some more tests to determine if you cps is bad or not. You can inspect the air gap between the signal rotor and the pickup coil projection. Just look in the TSRM if you don't know what I'm talking about. You can also check the resistance of the pickup coils. All of this information is in the TSRM page IG-16.
You might also want to test the igniter. That info is on page IG-15.
