Originally Posted by TimeAttackNick
...what i dont know is the information on the 2jzgte aristo. whats the difference between motors? only thing i know is that the arisot is MAp and the supra is MAF...
Actually in Japan, the MKIV Supra Turbo is also MAP-based (not MAF). The Aristo 2jz-gte and the Japanese-spec Mkiv Supra Turbo's 2jz-gte are almost identical in terms of performance characteristics. The primary differences are associated with fitting the engines into two different engine bays. For example, the oil pans are very different.
