If it smells like antifreeze then it is burning it. Only 2 ways you burn antifreeze, blown head gasket or cracked head.
Sounds like you have a cooling passage to cylinder head gasket leak. Allowing coolant to enter a cylinder but not an oil passage. Same thing happened to me, never had oil and coolant mix.
You can hope all you want, if you want 100% proof, do a block test.
