Thread: Antenna wire?
Old 03-23-2007, 09:36 PM   #1
tone loc
tone loc's Avatar
well for the atena to be connected to the head unt its one black wire and it if you take off the trim for the passenger side (the part on the frame of the car it has like 4 small screws), then there is like little hooks for the carpet(you just pull these out of the hole with a pair of pliers) and then there is a thing with two little clips under the carpet and you use a flat head screw driver to get that off and there should be a clear tube (for the back window washer fluid) and if you have a atena there will be a black cord and you can follow it back to your head unit.
