i did my 7m-gte swap 6 months ago. i spent about 2500. for the motor, harness, ecu, intercooler kit,igniter, valve job, metal head gasket, accordian hose, arp head studs, oil cooler, changed the whole cooling system such ass radiator, water pump, fan clutch, air flow meter,stock clutch, timing belt, hac sensor, 3 inch elbow, 3 inch down pipe, 3 inch cat back, seals for the crankshaft and a couple of parts here and there.
its good stuff though. not bad.
motor - 750
harness and ecu - 100
intercooler kit - 100
igniter - 50
valve job - 200
hks metal head gasket - 150
accordian hose - 60
arp head studs - 120
oil cooler - 20
radiator - 120
water pump - 40
fan clutch - 60
air flow meter - 50
stock clutch - 130
timing belt - 30
hac sensor - 25
3 inch elbow - 50
3 inch hks down pipe - 100
3 inch cat back - 160
seals for the crankshaft - 30
