Old 05-31-2005, 04:34 AM   #5
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
here's some tips from users from sf
mikkee123:
its possible. Takes time and patience. There are two 12mm nuts underneath the actual egr valve. You need an extension and the 12mm socket i think. With time and patience it will take you 30 min max. Also..you need to block off the egr vacuum line. It comes off of the throttle body, down under the intake manifold, to a vsv and then to the egr modulator. Cap off that line, and the 2 egr ports and you're set. Pretty straight forward
conundrum07:
You need the block off on the upper intake manifold. The other one on the lower manifold is not needed if you block off the EGR cooler on the back of the head (this way is better, keeps the heat away from the back of the head).
drjonez:
for blocking vacuum lines
-the one on the TB, just cap it.
-the one that comes off the metal vac tubing under the intake manifold (feeds the VSV under the intake manifold), just cap it.
dunno if you can view this
http://www.supraforums.com/forum/attachmen...tid=32713&stc=1
that's all i can seem to find for now
Pics of my build.
Do a diagnostic first!
