There are a couple of options. The one that holds the most hope for you is try finding ANY size socket that "almost" fits on the stripped nut but is just barely too small. Then, hammer that bitch on there as hard as you can until it is jambed on the nut. You will ruin the nut and whatever socket you use, but its the only way you will be able to get the leverage to take it off.
But even that method doesn't work 100% of the time. So use this method at your own risk!
Good luck.
