im sorry i meant to say those locations are for jack stands. put the jack under the crossmember/subframe jack it up to desired height, then place jack stands under the formentioned locations. i just ran out to take pics
this is the crossmember/subframe where you put the jack
this is where the jack stands go
heres a close up of the front one. see the metal where you set it?
