Old 03-31-2007, 12:10 AM   #32
dannydavi
dannydavi's Avatar
hey first off i really wanted to say this is an awesome technique, thanks for sharing. Second i got an error code 14: which is with ignition signal, diagnosis is no IGF signal to ECU... then it says "A" 7M-GE 6-8 which i dont understand, trouble area: ignition and ignition coil circuit, igniter and ignition coil, ECU. I also got trouble code 21: which is either oxygen sensor signal or oxygen sensor heater signal, So basically what im asking is can someone help me understand my trouble codes, and perhaps lead me in the right direction to eliminate my trouble codes, thank you.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
