sry
i was in a hurry to get to the shop. it sounded like it was lamens described. sry about that. on your t/b there is the tps. theres a yellow paint mark from the factory(index mark) the screw and mark should line up. the cam sensor should be about a third of the way up from the bottom of the adjustment slot and last pull off the vacum hose from the pressure regulator, put another on long enough for you to suck on. start the car and suck on it. if you taste gas its bad if the idle changes(listen closely) its good. if not its bad. check that stuff and get back
